Posted July 1, 200421 yr Do You think its Bad? I always Thought that it was good for gettin tthe old 2 Stroke off-roader going on the cold Monday morning! Your thoughts Please!!
July 1, 200421 yr If it's starting fine and perfect first time on a cold morning you must be blessed! :wink: My DT50 struggles to start even on a warm day when it was used only 2 hours ago. :cry:
July 1, 200421 yr Moderator Do You think its I'd say that you must have your cold down to a science! 8) ......of course, a bit of luck never hurt either :wink:
July 1, 200421 yr peronally i wouldn't put easy start anywhere near a 2 stroke :? if it's that bad to start then it needs fixed 8)
July 1, 200421 yr Moderator peronally i wouldn't put easy start anywhere near a 2 stroke :? if it's that bad to start then it needs fixed 8) Half the satisfaction of owning a 2-stroke, is sometimes becoming a WitchDoctor just to get 'em to cough to life.......always well worth the effort though :wink:
July 3, 200421 yr number1 cold start is a heroin to engines after a while you motor wont run without it number2 i wouldnt entertain putting it in a 2 stroke through of fucking the engine right up number3 never putcold start in a deisel engine as they womt last five mins beyond the first 3-4 times a guy in work blew his van engine up using it i put it n my mates mondeo turbo deisel and until its started the engine makes a terrible banging noise. all three of my dt125r started second kick guaranteed in all weather but 99% 0f the time it started first kick but easy start is a bigg nono
July 3, 200421 yr try proboost, it helps stop carbicing and cleans engine/carb or something or other, plus it majorly improves preformance on tha bikes its bloody great stuff i tell ya
July 3, 200421 yr im with mozzy man my DT starts 2-4 kicks even on the coldest mornings (touch wood) apart from if some wanker has fucked around with the killswitch, then my mates have to push me!!
