yamaha sr125
what is the best way to remove the cam followers
in the cylinder head im a bit stuck
please help if poss
please help if poss
According to the Haynes book of lies, you're supposed to remove the cams by threading a bolt into their shafts and then pull them both out.
I've found that this doesn't work, as I don't have a blow torch and I don't have any tools that will do the job.
Best bet is to take it to a garage and have them heat up the head a little bit, or if you have your own oven, then heat it up a little and yank the buggers out!
Hope this helps.
