DE-RESTRICTION ?!?!?!?!?
HI, I HAVE A 2006 DT125R....
NOW I HAVE LOOKED THROUGH LOTS OF FORUMS TRYING TO WORK OUT THIS EARTHING THE WIRE MALARKY.
PEOPLE HAVE NAME EVERY COLOUR OF WIRE, BUT I DONT WANT TO SCREW IT UP. SO CAN ANYBODY PLEASE GIVE ME THE CORRECT WIRE AND LOCATION AND ALSO HOW TO EARTH IT BEST.
THANKS
P.S A PICTURE WOULD BE AWSOME....
THANKS
Exactly what is the problem madmitchy? - need a bit more info I think.
:D
THANKS
Hi
Sorry no picture but i hope this helps
Going into the speedo is a four pin connecting block. There are 4 wires going into the block and only 3 wires coming out the speedo side. Just find the Green/Black wire going into the block, clip it to separate it from the block, and strip the end and join a small piece of wire to it (long enough to to join to an earth on the frame). When the Green/Black wire is earthed to the frame this stops the YPVS from retarding over 7000 RPM. The engine should rev freely now.
the best site to you get info from and where i took this from is
http://www.dtr125.net/tuningf.htm
Regards
Mark
