Posted June 23, 200916 yr According to Mr Haines the torque setting for the clutch pressure plate on a 2000(w) xj600s Diversion is 10Nm (70 psi) which doesn't seem very tight at all, also the clutch seems to rattle as well. Can anybody supply settings from Yamaha? Many thanks Mike
June 23, 200916 yr Personaly I'd just go with Mr Haynes, and theres many talked about fixes for the Div clutch, Its just the nature of the beast, if I can find it again I'll PM you with one I thought was a possible.
June 23, 200916 yr According to Mr Haines the torque setting for the clutch pressure plate on a 2000(w) xj600s Diversion is 10Nm (70 psi) which doesn't seem very tight at all, also the clutch seems to rattle as well. Can anybody supply settings from Yamaha? Many thanks Mike Hi Mike, the clutch rattle is normally badley adjusted carbs ..... along with oil delivery problems 10nm sounds about right Regards Jim
June 24, 200916 yr Author Cheers BWJ and Jim. I think I will get used to it because apart from rattle the bike is running superb. Thanks again both of you. Mike
