Posted June 22, 200916 yr I've just bought this very nice motorbike, but I have a problem I just need help to solve. I could understand, that only the flash light indicators didn't flash when I used the signal to turn, since the flashlights in the rear wasn't there, so yesterday I did start looking for the flasher relay and the wires, so I could get 4 new flash lights on the motorbike. But I couldn't find the relay and there was only the small wires on the front flash lights, with no connection at all, I think that the flasher relay should be seatet under the the fueltank, because I found an old rubber holder there, but I'm not sure at all. I've been looking on several wire diagrams, but not something I could realy understand. So my question is: Is there wires from the flash light indicator (right/left), that should go to the flasher relay and if there is, what colours should I be looking for. Sorry for my spelling, but I'm from denmark.
June 23, 200916 yr Moderator I've just bought this very nice motorbike, but I have a problem I just need help to solve. I could understand, that only the flash light indicators didn't flash when I used the signal to turn, since the flashlights in the rear wasn't there, so yesterday I did start looking for the flasher relay and the wires, so I could get 4 new flash lights on the motorbike. But I couldn't find the relay and there was only the small wires on the front flash lights, with no connection at all, I think that the flasher relay should be seatet under the the fueltank, because I found an old rubber holder there, but I'm not sure at all. I've been looking on several wire diagrams, but not something I could realy understand. So my question is: Is there wires from the flash light indicator (right/left), that should go to the flasher relay and if there is, what colours should I be looking for. Sorry for my spelling, but I'm from denmark. to the forum Pharo. I'll check it out tomorrow as I am a little tired right now!!
June 25, 200915 yr Author I've finaly solved the problem, I found the green and brown wires in the headlight casing and the flasher relay was in the frame, just right over the engine it was impossible to see. I did find it because I did place a new relay/new wires and then the original one did make some noise. I say thank you for the welcome in this forum and it will be used a lot, that I can promise Tomorrow at 7.30 in the morning, I'm going to see if I can get number plates for the bike, because I think it should be ready for it.
