Posted June 21, 200916 yr hi i have jus brought a 2003 yamaha aerox and i cant get it to run its got fuel going thought and ive buzzed all the wires and all working just wonderd if anyone else has had this problame ??????? cheers
June 24, 200916 yr Author mate you could have an air flow problem in ur carb or ur jets are blocked HI my jets aernt blocked thats one of the first things i checked and my air flow is fine everythin is working.its turns over got compresstion got fuel but it just wont fire ive been tho everything and have run out of ideas now so jus wondered if anyone has had this before ? thanks for your reply mate
August 19, 200916 yr is your reed valve and manifold clear? if the answer is yes. the only other problem i can think of is your choke, has the cable snapped or is the mechanism jammed?
August 19, 200916 yr remove air filter put a small omout of fuel in the carb from the filter opening then replace filter and try that ohh but when the filter is off and ure puting the fuel in make sure the throttle is open, or pull the plug and put some fuel on top of the piston then see wether it will fire
