Posted June 20, 200916 yr hi my float that sits in the carb is bent out of shape could anyone post a picture of theirs? i need to be able to clearly see the angles so i can put mine right thanks. Paul.
June 20, 200916 yr hi my float that sits in the carb is bent out of shape could anyone post a picture of theirs? i need to be able to clearly see the angles so i can put mine right thanks. Paul. i think you are pissing in the wind if you think some one is going to strip the seats off, tank off,air filter off and strip down there carb to take a photo, but what i can do is show you what it looks like with this photo xvs 125 dragstar hope this helps just seen your other post thought you were talking about your dragstar? as it is a yamaha owners site
June 20, 200916 yr Author i think you are pissing in the wind if you think some one is going to strip the seats off, tank off,air filter off and strip down there carb to take a photo, but what i can do is show you what it looks like with this photo xvs 125 dragstar hope this helps just seen your other post thought you were talking about your dragstar? as it is a yamaha owners site well the engine is Yamaha (an xv 125 virago ) so in my book its a yamaha bike. but thats a whole new topic but anyway chears for the pic iv been looking for hours trying to find something similar, and would you know where i can find the measurements for the float height ? either for the xv or the xvs as they look the same chears. Paul.
June 20, 200916 yr i can only give you the measurments for the xvs dragstar but it should be similar. fuel level(above the line on the float chamber) 9.5mm to 10.5mm the pilot screw 2 turns out hope this helps. some more info in no paticular order as computer went tits up
June 20, 200916 yr Author cheers m8 big help thankyou! hopefully il get that set then i can carry on re jetting! : )
