Hi guys
I understand that the blue spot caliper is an easy upgrade for my 1992 FZR1000.
Can I use calipers from other manufacturers or the gold spot ones?
Any help with improving my bike is appreciated.
Pete
The Goldspots will fit, but make sure they`re not the later radial ones.
The Goldspots are same as Bluespots, apart from the pistons are lighter, less prone to seizing and a little better performance.
You`ll also need the R1/R6/Thunderace master cylinder, as the original FZR master cylinder will make the brakes feel "wooden"
