June 19, 200916 yr I'm diagnosing an idle issue and would like to have a few people measure the voltage at the atmospheric pressure sensor on their bikes and report it back here. I've got an '05 R6, but I think the sensor and working range is the same for '03-'05 R6 and '6+ R6S. Might even be the same for the current R6, don't know. The atmo sensor is in the tail section, just in front of the storage bin, on the right hand side. Depending on the meter probes you have, you might be able to do this test by only removing the seat. The sensor has a three wire connector. It's opposite from the tipover sensor. Basically you leave the sensor connected to the harness and "backtap" the connector. Negative probe goes to the black wire (middle wire) positive probe goes to the blue/gray wire (probably the outboard wire). I need the VDC reading across that connection. Thanks if you can help out! Chris
