June 19, 200916 yr hi there im trying to rejet my carb but need to know whats the best way to go about it without spending too much cash id like info on how to check the settings for the pilot jet, needle jet and main jet to get the best settings for my bike chears .Paul.
June 19, 200916 yr Moderator Hi Paul..Why do you want to re jet? are you talking of the Sach or the baby drag?
June 19, 200916 yr Author Hi Paul..Why do you want to re jet? are you talking of the Sach or the baby drag? the sachs iv put a new exhaust and performance air filter on it and i just need to sort out the jetting cause it wont start unless i push it down hill in second gear! and me legs are getting tied but iv now found a new problem the float bowl seems like the previous owner has bent it????!!! so I'm searching for the float bowl dimensions so i can put it back to standard then i can begin jetting it
June 20, 200916 yr Author what is a sachs roadster? two stroke, four stroke, twin, single? its a 4 stroke v twin xv 125 engine the exact same one as the virago 125
