'78 XS400 Right Switch Wiring
What is the correct setup of the wires for the right handlebar switch? The harness has been cut from the switch and the switch is broken anyway. The wires I have going to it are this:
Red/White
Brown
Brown/White
Red/Yello
Blue
Blue
i figured out that the red/white and brown together are the kill switch and have that set up temporarily. Still not sure on the other wires though.
i believe i've got it now:
Red/White + Brown = Engine On
Red/Yellow + Blue/Black + Blue = Headlight On
Blue/White + Ground = Starter Motor On
I've got my Kill switch working and my light switch working now(well the low beam atleast, high is probuably blown) but I can't really test the starter button because I believe the starter is toast or at least has a bad connection to the solenoid. Not too worried about that right now, but will mess with it later. Does everything sound right here?
