Posted June 16, 200916 yr when i got this bike i tore down the top end, only to find the piston in backwards and a very shoty base gasket . after looking closely and picking alot of old gasket material out of the oil journals and transfer ports i reassembled with new base gasket. and it still wont so much as fire. I also cycled through the timing and not a sputter. does anyone know about what these should have for compression.
June 22, 200916 yr Author so 30 pounds wont work....?lol turns ot its ten thou undersize i was a little suspicious when the jug slid on so easily
