June 14, 200917 yr Morning all, i done the fork oil seals on my yb100 last weekend, took it out for a run yesterday and it felt hard on the front end, have i put too much fork oil in (approx 160mls) or not enough i didn't fill it right up it was about 2cm from top, regards alec
June 18, 200917 yr Sounds like there is too much fork oil - I know its a pain but I would remove them and empty the oil into a clean container and measure how much you have got - you should have around 320ml. If you have more just refill each leg with 160ml and you should be ok. :D
June 18, 200917 yr just a quick question.. not that i need to know as for now, but how does one change fork oil?? do the seals just rip out, pour oil, and plonk a new set of seals on? thought id ask, rather than getting a pair of long nose pliers to my forks!
