June 13, 200916 yr Hi, just joined your site, looks great!! Can you advise re purchase of my next bike please? Am interested in a Roadliner which is an U.S version (I'm sure you know this!!) have also seen midnight star. The midnight has all the chrome of the roadliner, so I cannot see any difference. Is the performance the same? The dealer with the roadliner says his is the more powerful bike ( 124 ft lbs torque) He implies the difference is very noticable - but then he would, wouldn't he?! Did test a Strato last yaer which was U.K spec, and really was under powered. Hoping to pick your brains. Thanks so much, in advance.
June 14, 200916 yr Hi, just joined your site, looks great!! Can you advise re purchase of my next bike please? Am interested in a Roadliner which is an U.S version (I'm sure you know this!!) have also seen midnight star. The midnight has all the chrome of the roadliner, so I cannot see any difference. Is the performance the same? The dealer with the roadliner says his is the more powerful bike ( 124 ft lbs torque) He implies the difference is very noticable - but then he would, wouldn't he?! Did test a Strato last yaer which was U.K spec, and really was under powered. Hoping to pick your brains. Thanks so much, in advance. here is a side by side us specs from Yamaha Motor Home Roadliner / midnight star Bore x Stroke 100mm x 118mm/ 97 x 113mm Carburetion Twin-Bore electronic fuel injection;throttle position sensor/ 40mm Mikuni CV w/throttle position Compression Ratio 9.48:1 / 8.3:1 Final Drive Belt Belt Ignition TCI: Transistor Controlled Ignition / Digital TCI Transmission 5-speed; multiplate wet clutch/ Wide-ratio 5-speed Type 113-cubic-inch air-cooled 48° V-twin / 102 cubic-inch air-cooled, pushrod OHV, 48-degree V-twin you can check out specs at http://www.starmotorcycles.com/star/overview_byo.aspx
June 15, 200916 yr I think those specs are back to front. The Midnight is a 1900cc bike (113 cubic inch) or thereabouts.
June 15, 200916 yr as stated i got my specs from Yamaha http://www.starmotorcycles.com/star/produc...484/0/home.aspx the only 113 ci are the 2 Roadliner Stratoliner and the Raider
June 16, 200916 yr Moderator I think those specs are back to front. The Midnight is a 1900cc bike (113 cubic inch) or thereabouts. Actually its not just the 1900 honey My 950 is a Midnight Star too.........
June 16, 200916 yr Actually its not just the 1900 honey My 950 is a Midnight Star too......... Yeah, but it's a 950, 1300 or a 1900, according to the Brochure. The specs were saying it's a 1700, which was the bit that didn't make sense.... Confoozed!!
June 16, 200916 yr Yeah, but it's a 950, 1300 or a 1900, according to the Brochure. The specs were saying it's a 1700, which was the bit that didn't make sense.... Confoozed!! that would be 102 CI (1670) some times thy round up and call it 1700
June 17, 200916 yr that would be 102 CI (1670) some times thy round up and call it 1700 I think the confusion is in the name... Road Star (Midnight ).... that has the 1700 lump same as the Warrior.... never officially imported into the UK. The new Midnight Star range.... is the 950 1300 and 1900.... I think they are called V Star in the US... I think the 1700 lump is an old air cooled unit. Still I stand to be corrected Stu
June 17, 200916 yr I think the confusion is in the name... Road Star (Midnight ).... that has the 1700 lump same as the Warrior.... never officially imported into the UK. The new Midnight Star range.... is the 950 1300 and 1900.... I think they are called V Star in the US... I think the 1700 lump is an old air cooled unit. Still I stand to be corrected Stu just maybe the name thing so any one that want to compare Yamaha V-STAR bikes to the roadliner can go here http://www.starmotorcycles.com/star/produc.../0/compare.aspx
June 18, 200916 yr OK, that makes sense, yeah. Dragstar - 125, 250, 400, 650, 1100. Wildstar - 1600. Warrior 1700. Midnight Star - 950, 1300 or 1900. Why can't they just have one bloody name!!!!!
June 19, 200916 yr OK, that makes sense, yeah. Dragstar - 125, 250, 400, 650, 1100. Wildstar - 1600. Warrior 1700. Midnight Star - 950, 1300 or 1900. Why can't they just have one bloody name!!!!! Yep and why cant we have the full range of bikes in the UK! Warriors look great, never ridden on though
June 25, 200916 yr OK, that makes sense, yeah. Dragstar - 125, 250, 400, 650, 1100. Wildstar - 1600. Warrior 1700. Midnight Star - 950, 1300 or 1900. Why can't they just have one bloody name!!!!! There is a Royal star as well - 1300 (79-cubic-inch / 1294cc)
October 27, 200916 yr hi, i own a 2005 yamaha roadstar midnight 1700 and my brother has a 2006 yamaha stratoliner (same as roadliner but with bags and some) the roadliner has a 1900cc engine while the roadstar has a 1700cc engine and is fuel injected for the 2009 model year. i stand at 5'9" tall and weigh 235 lbs and i think that the roadliner is too wide for me. i think the best thing to do is to go to a dealer and sit on each bike and if possible test ride them. i love my roadstar and it's not a small bike, but very powerful also. good luck on your new toy.
