Help XS1100
NatesXS1100
This post is 5494 days old and we'd rather you create a new post instead of adding to this one. You can't reply in this post.
THe second cylinder seems to not fire as good as the other four im kinda new at all this bike tech but if anyone has any tips that would be nice :)
Yamaha XS1100 special
Changed plugs checked for spark, there is definitly spark
changed all the gas lines
and well it just doesnt seem to run right
well it could be as simple as the carbs need to be cleaned and or rebuilt or could have restricted air flow that would be what i would check first
check the wires under the left engine cover as u sit on bike this is the vacum advance. while the bike is running gently tug or push the two small stretchy wire you should get a noticeable difference in rpms replace with longer heavier wire. and i do agree with the others clean your carbs and try them and then clean them again and then once more just for fun
There is a mantra on these bikes.
Clean the carbs.
Check them and then clean them again.
Now that their clean, clean them again.
Make sure you can get carb cleaner to blow through ALL the little passages, and make sure you remove the jets and clean them out. Then make sure to do a GOOD carb sync, as these things are VERY sensitive to carb sync issues.
Also while this is a great site, there are both US and UK specific XS1100 sites, although both sites have members from all over the world. The US site is xs11.com and I don't remember the URL for the UK site, but IIRC there is a link on the US site somewhere.
