June 12, 200917 yr hi all, i have a fzr600r and the output shaft has had it, prob easer to replace compleat engine i think. thats the probelem strugling to find one thats cheaper than buyin a whole bike.any one any idears? could any other engine bolt streight in. hope to here back thanks Dave.
June 14, 200917 yr Author hi dave! how ya doin? are your from Ireland? yep living in england at the moment.still gotta support your fag.
June 15, 200917 yr How,s it goin? The Thundercat engine should fit your 600r. You,ll need the CDI, loom, etc. from a Cat also.
June 16, 200917 yr Author How,s it goin? The Thundercat engine should fit your 600r. You,ll need the CDI, loom, etc. from a Cat also. nice one, the whole loom? dont know much just so i can sorce the right parts.ta dave
June 17, 200917 yr nice one, the whole loom? dont know much just so i can sorce the right parts.ta dave I,m not sure but the Thundercat uses a TPS set up for the carbs so I,d imagine you,ll need the Cat loom.
June 17, 200917 yr Author I,m not sure but the Thundercat uses a TPS set up for the carbs so I,d imagine you,ll need the Cat loom. hi thanks, got a new 600r lump today i say new should say another one.gonna put it in tomorow first time swoping an engine so fingers crossed. did cost £300 quid off one of those part finder sites,promised it would be ok. thanks again. dave
