DT125X chain & sprocket advice
My DT125X needs a new chain and sprocket set after covering 13k miles.
Any advice on a decent set?
I know Renthal have a reputable name, but I can't find a renthal set for the DT.
Is a standard yamaha kit the way to go?
Any advice gratefully received,
Jam353
Always make sure you get a good o-ring chain or better (dont be stingy) also dont buy light weight ally sprockets from Talon or Renthal as they wont last 5mins so the 'heavier' type ones are the way to go, so to make things easy you wouldnt be doing too bad if you bought yamaha parts but i found a good set of c&s online for £70 and lasted around 6kmiles and are Tsubaki so not a bad make. ;)
