reving problem
hey all i own an r125 and it has developed a reving problem when under load.
its a hard one to explain but.....
when under load in any gear but most noticable in 3,4,5 if i pull the throttle back instead of it being a smooth brrrrrrrrrrrrrr from 4k upto redline it sort of stops and starts more like brrr,rrr,rrr,rrr,rrr,rrr if you understand me lol....
Ive changed the plug and it made it a little better and i have checked the air filter and that seems ok
the oil level is fine and is on the dipstick
does anyone have a clue what is causing this.
thanks
Jas
your bike needs to see a speech therapist. :lol:
try the fuel filter?
lol
there is only one and its inside the tank it is attatched to the pump and looks clean :(
i cant see another one it come directly out the tank to the injector.....;
Jas
im not sure if your bike has one, but (and i know that this sounds odd) my suburban did something similar. turned out that it was a bad o2 sensor. it was telling the brain that the engine was running lean when it wasnt. it would adjust fuel for a sec, and find that it was rich. back to lean. etc. br.....br.....br....br....br.....br......
im gonna let the experts here help ya.
Not sure about the sensor but I know it's getting real annoying now and I can't afford to take it in till end of the month :(
A better descrption might be that every half second when accelerating it sounds like the clutch slighty bites then stops then bites then stops but if I drop down a gear or am braking it still does it
HELP LOL
Jas
