June 7, 200917 yr Hi I've been having a few problems with carbs so cleaned them and stuff, now I'm trying to sort out the fuel levels. The info I've found says between 4.5 and 6.5mm below the line. I've tried this but now I'm having trouble starting the bike and it sounds lean. Is this really the correct fuel level? ~Rachel
June 7, 200917 yr Hi I've been having a few problems with carbs so cleaned them and stuff, now I'm trying to sort out the fuel levels. The info I've found says between 4.5 and 6.5mm below the line. I've tried this but now I'm having trouble starting the bike and it sounds lean. Is this really the correct fuel level? ~Rachel hi is it flooding & have you set the float tab correctky to the specs in the manual if not it will flood if its set to high or if not enough itll starve of fuel
