yamaha tzr clutch plate fitting
I have a yamaha tzr 125 that needed new clutch plates, I replaced these and the issue was not resolved.
I was told later by a friend that they need to be put in a certain order and there will a differance beetween the plates to help or markings.
I cant see any of this and all the 6 plates look the same.
So is there an order or is there another issue im just not seeing.
Hi Tony
You will notice 'dots' on both friction & plain plates (if genuine) which should line up which the arrow on the clutch boss, at which point the pressure plate will fit snug to the boss. If the plates are non genuine you may have to adjust their position to allow the pressure plate to fit snug to the boss
Regards Jim
