yzf 750 ECUs
Does any body know the difference between the 93 94 ecu and the 97 ecu. i noticed the larger connector has 2 less pins and the smaller connector has 1 less pin on the 93 94. Can it be bypassed or hardwired to work? and what do the other pins connect. little help little help anybody. I hooked up a V&H powerpak and it wouldn't fire. Sounds as there is no ignition and it wouldn't power the fuel pump. help please!
Can`t remember exactly, but the later YZF750`s has the TPS (Throttle position sensor), i`m sure i read that its something to do with that.
