June 3, 200917 yr Does anyone have a homegrown method of removing the lower steering stem bearing without a bearing puller? Thanks, Kevin
June 3, 200917 yr Moderator Does anyone have a homegrown method of removing the lower steering stem bearing without a bearing puller? Thanks, Kevin cut very carefully with a dremmel and chisel out the last bit
June 4, 200917 yr cut very carefully with a dremmel and chisel out the last bit Ditto, that works great!
