Posted June 3, 200915 yr The Petrol tank im gonna be putting on my latest project is in poor condition. Im not so bothered about the outside but the inside is awful, rust etc. Whats the best way to clean it out? i presume you can fill it with a solution and let it soak away at it? Any ideas? Cheers andy
June 3, 200915 yr Moderator The Petrol tank im gonna be putting on my latest project is in poor condition. Im not so bothered about the outside but the inside is awful, rust etc. Whats the best way to clean it out? i presume you can fill it with a solution and let it soak away at it? Any ideas? Cheers andy nut and bolts, parafin and shakey shakey. I would suggest lining the tank with POR15, its a kit with acid etcher and the 2 pack sealant. I'm assuming your from UK as you said petrol, so www.frost.co.uk is a good supplier drweps
June 4, 200915 yr Author nut and bolts, parafin and shakey shakey. I would suggest lining the tank with POR15, its a kit with acid etcher and the 2 pack sealant. I'm assuming your from UK as you said petrol, so www.frost.co.uk is a good supplier drweps Thanks ill have a look around
