Yzf750R Starter problem
Hi, having trouble starting my YZF750, sometimes the starter engages but most times now it just spins out. Someone said it could be the sprag clutch?
Is it going to be:
A. Expensive
B. Difficult
C. DIY job or bike shop
Please help. bl**dy thing stalled at the lights this morning and wouldn't catch, v annoying when you've just filtered past everyone to get to the front.
It's a 1994 standard R model, 28K on the clock.
Cheers
i havent done this job myself, however it does require stripping the ngine down to get access. The problem with the fzr1000, yzf750 type engine is that once you take them apart all the other stuff needs attention. If you are able it may be worth a go, then again you might wanna just get another engine (fzr1000 will go in with a little work).
other solution, get good at bump starting a behemoth!
