June 2, 200916 yr Hi Guys, I am currently restoring a 350B which can be seen here 350B restoration The 350B restoration has been waiting for an 'all new' electronic ignition system, being developed by Electrix. Its an 'all singing and dancing' system that not only replaces the points plate but also the coils and everything in between !!! Well Electrix say its ready and currently running on an LC What the guys at Electrix want is to borrow a running 250/350 A/B for a weekend, so they can do a final fitting test. Unfortunatly the 350B restoration is not ready to run yet, so it cant be used. They are based around Oxford, anyone prepared to lend them your bike for a weekend ?? I'm sure there is a good deal there for someone who can help (we have order No1 ) PM me if you can help Thanks Steve
June 2, 200916 yr Hi Guys, I am currently restoring a 350B which can be seen here 350B restoration The 350B restoration has been waiting for an 'all new' electronic ignition system, being developed by Electrix. Its an 'all singing and dancing' system that not only replaces the points plate but also the coils and everything in between !!! Well Electrix say its ready and currently running on an LC What the guys at Electrix want is to borrow a running 250/350 A/B for a weekend, so they can do a final fitting test. Unfortunatly the 350B restoration is not ready to run yet, so it cant be used. They are based around Oxford, anyone prepared to lend them your bike for a weekend ?? I'm sure there is a good deal there for someone who can help (we have order No1 ) PM me if you can help Thanks Steve Hi Steve, odd concept ... the only fitting issue would be perhaps the taper & keyway on the crankshaft (this assumes that the company is producing a CDI that is simular to the LC std one .. genni plus sparks). I would guess that a direct crib of the LC CDI would work on a 350B but if they have gone to far away from the LC ignition curves & geni/pluse coils there is a chance its a suck it & see thing !!! Regards Jim
June 2, 200916 yr Author do you mean electrex? or is this a new company? Yep, its Electrex, they are telling the owner of the bike i'm restoring that the kit is finally ready ??? Is there something i should know about Electrex ?? Do you know a 250/350 A/B we can use ?? Steve
June 2, 200916 yr Moderator Yep, its Electrex, they are telling the owner of the bike i'm restoring that the kit is finally ready ??? Is there something i should know about Electrex ?? Do you know a 250/350 A/B we can use ?? Steve electrex is a good company, if it were electrix than i would be doubious as they might be trying to drum up trade by association!! ( never heard of them anyway) as for the rd's I'd PM merv as he is mod on the rd aircooled site and speak with him!
June 2, 200916 yr Moderator electrex is a good company, if it were electrix than i would be doubious as they might be trying to drum up trade by association!! ( never heard of them anyway) as for the rd's I'd PM merv as he is mod on the rd aircooled site and speak with him! Steve SFBrain is also predominanly on aircooled RD site, I guess the question has already been asked there....
