xjs 900 carburettor problems
I am going to see a 900 diversion 1998 model with the intenton of buying. However the fellow selling it says that it starts and runs only to about the end of the street. He thinks it may be a carburettor problem. Does anyone out there have any suggestions what may be the cause? And does it sound expensive or difficult to fix? He is selling at a good price because he doesn't know how to fix it.
Thanks.
jebby7
Thanks.
jebby7
Hi Jebby,
go steady with this one but I would think it has a fuel pump/tank/filter problem but you may have an ignition problem. As the 900 normally never stops (unless stood) I would think on the former !
Regards Jim
Hi Jebby,
Regards Jim
thanks I'll have a look at those things. help appreciated,thanks
jebby
jebby
Hi Jebby,
if you can just get hold of the bike and run it at high RPM if it holds back and gives an odd noise from the cylinder head area you could just strip the carbs & air valves out to fix it .. but I need some more info
Regards Jim
Hi Jebby,
Regards Jim
Appreciate all the help Jim. Unfortuneately I got a phonecall from the seller tonight saying that someone else had beat me to it and had bought it first :( . Thanks again.
jebby
jebby
Hi Jebby,
just find another & if you need help let me know !
Regards Jim
