SR125 Carburetor Question
Hi everyone,
I've just got to the final furlong on my efforts to mend the SR125.
(Turns out the major problem was a dropped exhaust valve)
So, the top-end rebuild is now complete, valves and cam chain timing set up... i think
Today I filled the tank but the fuel just drops straight through my carburetor. When it was disconnected I noticed that it tends to rattle slightly when not still/horizontal. Q.1Is this normal?
Thanks.
Oh yes one other thing - different subject,
Q.2There are three marks on the rotor it looks like this |.....|----| (ignore the full stops they're just spacers but the hyphens represent a continuous line)
Would it be correct that the middle vertical line is TDC?
Thanks for your help...
J
Hi everyone,
Thanks.
J
As for the marks, they may be centre at TDC or they may be ignition timing marks, centre at correct timing and the others at acceptable + or - from correct. you can usually feel for TDC through the spark plug hole with something like a terminal screwdriver, this will show what these marks are. The carburettor, sounds like something is loose, maybe the float needle valve has somehow dropped into the bowl, hard to comment really but it looks like you will have to investigate further
If the carb is empty you will be able to hear the float shake up/down. Sounds like the needle/seat are worn or dirty.
