Noise movement
Hello!
Virago XV 125' 98 - engine extra work, but start and movement, regardless of which gear is heard noise from the transmission. Oil is changed. The same noise and it was when purchased.
The question is this normal for pattern?
Greetings!
Sorry for writing, but I do not know the language.
Hello!
Greetings!
:welcome: to the forum sebulba.
can you take it back to the place you bought it from?
sounds like a bearing!!
I do not want to give it.
Not understand, what is \"bearing\" ???
pasted it into the thread for you
drewps
nice bike
a "bearing" is what the gearbox shafts spin on inside the gearbox itself, it can ruin your gearbox so get it fixed! ;)
Okay, last question - Is it possible to noise coming from the loose chain?
:rolleyes:
