May 29, 200917 yr has anybody else had this problem? i currently have an 05 plate dt125r and i have a nice set of brand new thor quadrants but i really cant change up gear as i cant bend it enough to flick it up! could it be that they need flexing in or something? i used to have a 02 plate dt125 and i had no problems changing with them! has anybody had this problem or can the gear selector be changed in anyway? any help welcome'd
May 31, 200917 yr has anybody else had this problem? i currently have an 05 plate dt125r and i have a nice set of brand new thor quadrants but i really cant change up gear as i cant bend it enough to flick it up! could it be that they need flexing in or something? i used to have a 02 plate dt125 and i had no problems changing with them! has anybody had this problem or can the gear selector be changed in anyway? any help welcome'd i've got the same problem, bought a brand new pair of boots but cudnt change gear because i cudnt feel the gear lever lol but ive got my uncles old boots which are quite old and worn in alot and i can change gear in them fine but i also got a pair of motocycles shoes and there just as good as worn in boots, the more u wear them the more they are going to wear in but that could take a while
May 31, 200917 yr I had the exact same problem with my Gaernes so i un bolted the gear shifter and moved it up a spline (sp) makes it soooo much easier to shift gear now. Trust me try it out.
May 31, 200917 yr Also a weeks worth of riding wore my boots in and now comfy as slippers (unless you walk in them)
June 1, 200917 yr Author cheers for the comments guys i upped the selector a few and its fine now with my boots on but with trainers on i have to hover my foot over the peg lol! thanks
