Posted May 29, 200915 yr One of my spark plug wires came apart yesterday when i was working on my bike, are they replaceable? if so where can i find some, or what type do i need? thanks guys
May 29, 200915 yr One of my spark plug wires came apart yesterday when i was working on my bike, are they replaceable? if so where can i find some, or what type do i need? thanks guys Hi, in the UK the answer would be yes but your bikes may be different .... look at the coils if they appear to have a plastic 'nut' where the ht lead enters you will be able to replace the lead with std HT lead ... but if you have a wasted spark coil (2 leads from one coil) these tend to be moulded in so therefore you would have to cut at the break use the little inline connector and add a new lead ... but they dont tend to work to well ! Regards Jim
May 29, 200915 yr what part of the wire "Came apart"? Did it come loose from the coil, break somewhere in the middle, or come free of the spark plug cap? If it's from the coil or a break in the middle, it's as Jim said (though my '78 xs400 didn't have the wasted spark coils but still had the wire moulded in). If it's just loose from the spark plug cap, that's a pretty easy fix, and can be found at most suppliers of parts.
May 29, 200915 yr Moderator they are normally bonded in the coil, but an article in the xs1100 club website had them dremel out the side to take out the cable. If yours has come out completley, then in the hole that is left, there is a brass needle for the central core to connect to. You can then 5 min epoxy the cable back in. I used standard multicore HT lead as this will connect to the needle better rather than single core stuff. drewps
May 29, 200915 yr Author they are normally bonded in the coil, but an article in the xs1100 club website had them dremel out the side to take out the cable. If yours has come out completley, then in the hole that is left, there is a brass needle for the central core to connect to. You can then 5 min epoxy the cable back in. I used standard multicore HT lead as this will connect to the needle better rather than single core stuff. drewps it was the cap that came off of the wire itself, i pushed it back on and it seemed to work, but it was starting to show some corrosion so i was hoping there were replacements.
May 29, 200915 yr Author oh and thanks for all the help, i have been using the seach function, but its not really helping much, so thanks for putting up with all my questions here.
May 29, 200915 yr Moderator it was the cap that came off of the wire itself, i pushed it back on and it seemed to work, but it was starting to show some corrosion so i was hoping there were replacements. you need to screw it in, "ooh missus!"
May 30, 200915 yr you need to screw it in, "ooh missus!" are you on about screwing again !!! ? Regards Jim
