1984 xj600 master cylinder rebuild question
I am trying to rebuild a master cylinder off of a 1984 XJ600. The problem is I don't have the old one to follow and all of the images I can find do not provide a clear view of the order to rebuild. My major probelm is that I have two seals that are different and can't tell which goes first.
The kit contains
1 seal with divets in the outer edge (I think to let air pass by when expanding)
1 smooth seal
1 washer
1 plunger
1 divider that appear to seperate the spring from a seal
1 clip
1 spring
1 cover
Any help would be most appreciated.
The kit contains
1 smooth seal
1 washer
1 plunger
1 clip
1 spring
1 cover
Hi,
I guess I need to PM you ... and I'll give you the answers !!!
Regards Jim
