Posted May 28, 200916 yr I've purchased an OEM 40T rear drive sprocket. Now I need to get a front sprocket, but I wanted to ask you guys some questions before I do.. just so I can learn a bit. Are there certain size sprocket combinations that are required? Like 16/40? Or can I use a different front sprocket with a 40 tooth back sprocket. What will give me better mpg, or lower RPMs at higher speeds? I'm getting confused with this stuff Thanks!
