freshbuz Posted May 26, 2009 Share Posted May 26, 2009 I've got a DT 125 been sitting for years but will be revived. Anyone know the points setting on this bike? Any other hints would be greatly appreciated. Thank you. Freshbuz in Iowa. Link to comment Share on other sites More sharing options...
JimR Posted May 26, 2009 Share Posted May 26, 2009 I've got a DT 125 been sitting for years but will be revived. Anyone know the points setting on this bike? Any other hints would be greatly appreciated. Thank you. Freshbuz in Iowa. Hi, the setting is the points should just open (break) @ 1.8mm btdc. To measure 1.8mm you will need a dial guage & stand you can not get an accurate reading any other way, if the timming is incorrectly set you can suffer from either a hole in piston, no spark or general bad performance .... If you want to know the method on correct adjustment just ask ! Regards Jim Link to comment Share on other sites More sharing options...
