Posted May 26, 200915 yr hi i've got a 2006 FZ6 not has it long only a couple of weeks. the battery went flat and i've been having to bump start it, i charged the battery and it started, went for a 60ish mile run, pulled up for a quick cuppa and then wouldn't start again. i'm guessing it may be the alternator or something affecting it being charged when running, also at low revs - 3-4RPM, it is missing slightly when slowing down, this is really annoying as you only really slow down in these sort of rev's when in traffic, any ideas... its booked in for a check at the shop i bought it from just seeing if anyone knows what this could be so i could give them a heads up also the engine managment light flashed on the off but didn't effect how it ran and wasn't even on a second cheers guys
