Anyone fitted a 125yz front forks on a dt125r
As its says rly, has anyone did it.Im guessing that i will have to change the yokes and all the rest,But will i be able to fit a speedo on so that i can see speed etc
or...
Does anyone know where i can get some really good front and rear suspension as i went on my first mx track the other day and omfg i love it, just when you land the shocks or not the best as you can guess there not meant for it.
I will get a yz125 etc but i really cant afford it atm so just went to beef my dt125r up a bit as i does the job,By the end of the day i was over taking must of the ktms,yz etc and keeping up with some of the other guys. Mx is the way for me.
  • 3 weeks later...
you can use the yz forks if every thing measures up,the kicker is that the yz wheel doesn't have the drive for a speedo. This can be fixed with an electric digital speedo from a bicycle the one that has a magnetic pickup that u mount on the wheel i recommend the use of zip tyes on that pickup. these are fairly cheap and can be ordered at any good bicycle store or if it fits u can mount your current wheel on the yz forks and retain your original speedo.
