Posted May 25, 200916 yr Ihave a rather annoying problem with my Yamaha FZR 1000 EXUP it stalls at 4000rpm and i have gone through ta exhaust valve and the servomotor and ruled them both out. Maybee its the cid ignition but before i go out to buy a new one i would like to hear from anyone who has had similar problem and on how they fixed it. Someone told me it also could be the ignition coil. Hope to hear from someone qualified Ron
May 28, 200915 yr Author It just wont run any higher and if i switch it off and on again quickly then it runs normal until i get below 4000rpm
June 27, 200915 yr It just wont run any higher and if i switch it off and on again quickly then it runs normal until i get below 4000rpm Have you unplugged the exup motor? That could be it. Plug it back in and retest
