XS650 rattle
Can anybody shed some light on this.
My 1977 xs650 of 25000mls has a strange rattle when I start it up then dissapears in about a minute or less. It sounds a bit like piston slap but then it goes away?
I have checked and adjusted the tappets and cam chain (cam chain did not need adjusting).
It seems like something is waiting for oil then when it gets some it stops rattling.
It runs really well otherwise, I am just a bit concerned about this noise on start up.
Any ideas?
John
get someone to start it and hold a long screwdriver to your ear and the engine where you think i might be.
If you can pin pont the aea maybe soem one can shed some light on your problem!!
Any ideas?
John
Hi John,
I've had that one loads of times in the late 70's believe it or believe it not :- you need to fit a new cam chain. The first time I heard that noise it ended up with a factory tech guy visiting the dealership I worked in to asess this noise and it turned out to be the chain .... Replacing the chain is a pain in the butt as it's an engine out job but once you've done a few you can get it down to a couple of hours as long as the engine comes out of the frame easy and those damm exhaust studs don't break off !
Regards Jim
Hi John,
Regards Jim
So it's not pending doom then? :rolleyes: ....... I have a 2-300 mile trip planned soon, Is it likely to implode on me and take my legs off or just rattle for a while on start up? :huh:
Thanks so far, :D
John
Thanks so far, :D
John
Hi John,
it will just rattle on startup my own XS650 suffered from this noise and managed to cover about 4000 before I got around to doing it (that included a run from Worcter to Glasgow & back in 24 hours !
Regards Jim
