May 23, 200916 yr I need some real talent here fellas. It has nothing to do with the gas. I have drained my carb bowls, checked the petcock.......I have taken the carbs off and put them back on. I AM GETTING PISSED!!!!!!!!!! Once again, the bike will start and run when resting on its kickstand. Then once you tip the bike up, when about level the bike dies. I am at a complete and total loss. Is there something in the engine maybe, like a screen for the oil. Something clogging when the engine is tilted? I don't think it is a water issue now, considerin I washed the bike about two-three weeks ago. PLEASE HELP ME, or I am going to set some dynamite onto this f*cking bike!!!!
May 23, 200916 yr Moderator I don't think it is a water issue now, considerin I washed the bike about two-three weeks ago. PLEASE HELP ME, or I am going to set some dynamite onto this f*cking bike!!!! Why did you say water isnt an issue now, like were supposed to know something? It does sound like water in a carb float bowl possibility. If they are ok though dont forget to u tube the ultimate remedy...
May 23, 200916 yr Moderator check float levels, tilting bike affects the right carb, so it could be flooding or starvation. either way I'd strip the carbs down. drewps
