May 21, 200917 yr HELLO I WAS JUST WONDERING IF SOMEONE COULD HELP ME OUT ID LIKE TO REMOVE THE BAFFLES ON MY STOCK EXHAUST IF I DO THIS WILL I HAVE TO GET THE CARBS REJETTED THANKS FOR ALL THE HELP
May 22, 200917 yr Hi, If it's a 2 stroke, you're crazy. You will end up with no power and a bill for a new motor. If a 4 stroke get an aftermarket pipe and keep the one you've got to put back when you find the bike has lost power and is hard to start and runs like a pig. Regards.
May 22, 200917 yr Author Hi, If it's a 2 stroke, you're crazy. You will end up with no power and a bill for a new motor. If a 4 stroke get an aftermarket pipe and keep the one you've got to put back when you find the bike has lost power and is hard to start and runs like a pig. Regards. very helpfull thank you i would just like to get it to make a bit more of a rumble its pretty quite as it is right now
May 22, 200917 yr Moderator very helpfull thank you i would just like to get it to make a bit more of a rumble its pretty quite as it is right now If its the V star you are referring to there must be aftermarket pipes available, such as Vance and Hines, you may be best looking at these before doing anything drastic, ask our Goff, she had some aftermarket pipes on her 650....
