High pitched rattle around the engine on dt 125 x
the sound is really high pitched when the bike is started but when you change gear it goes untill you proceed higher in revs it sounds like it is some sort of bearings somwhere but the noise to me sounds like it comes from the front of the engine.
I thought it could be the chain as well but it is much louder than that, it is as if a bolt is rattleing around in the gears, also the gears are a little stiffer. Any suggestions or help would be appriciated as i am a noob when it comes to engine.
