leigh dt 125 Posted May 13, 2009 Share Posted May 13, 2009 hi ive got a dt 125 r 2002 , i think its lost some power beacuse first of all it was 75mph top speed on the clock, but now it struggles to go over 55mph and its never got to 75mph since any suggestions thanks Link to comment Share on other sites More sharing options...
JimR Posted May 13, 2009 Share Posted May 13, 2009 hi ive got a dt 125 r 2002 , i think its lost some power beacuse first of all it was 75mph top speed on the clock, but now it struggles to go over 55mph and its never got to 75mph since any suggestions thanks Hi Leigh, since when ? have you altered the bike some how or when did the perfomance drop off ? Regards Jim Link to comment Share on other sites More sharing options...
leigh dt 125 Posted May 14, 2009 Author Share Posted May 14, 2009 Hi Leigh, since when ? have you altered the bike some how or when did the perfomance drop off ? Regards Jim ive had the bike for about 2 months and within that first week of having it, it was fine then about 2 weeks after, it started to lose power, and no havnt done anything to the bike except clean it but i was clocked at 65 in my dads car but my spedo said 55 so it might just be the spedos wrong but im not sure Link to comment Share on other sites More sharing options...
JimR Posted May 14, 2009 Share Posted May 14, 2009 ive had the bike for about 2 months and within that first week of having it, it was fine then about 2 weeks after, it started to lose power, and no havnt done anything to the bike except clean it but i was clocked at 65 in my dads car but my spedo said 55 so it might just be the spedos wrong but im not sure Hi Leigh, how many miles has the bike covered ? Regards Jim Link to comment Share on other sites More sharing options...
leigh dt 125 Posted May 14, 2009 Author Share Posted May 14, 2009 Hi Leigh, how many miles has the bike covered ? Regards Jim its done about 7700miles Link to comment Share on other sites More sharing options...
JimR Posted May 15, 2009 Share Posted May 15, 2009 its done about 7700miles Hi Leigh, if the bike has not been serviced it may require one .... 2 stroke motors tend to build up carbon within the exhaust system which tends to restrict them, can you 'red line' the bike in the gears above third ? If not this would indicate a carbon build up. The speedo error you have is quite great and it may be worth checking this out also (assuming the old man's car's clock is correct ! Regards Jim Link to comment Share on other sites More sharing options...
leigh dt 125 Posted May 15, 2009 Author Share Posted May 15, 2009 Hi Leigh, if the bike has not been serviced it may require one .... 2 stroke motors tend to build up carbon within the exhaust system which tends to restrict them, can you 'red line' the bike in the gears above third ? If not this would indicate a carbon build up. The speedo error you have is quite great and it may be worth checking this out also (assuming the old man's car's clock is correct ! Regards Jim no i cant red line it above 3rd gear , maybe best to get it serviced because first thing in the morning it smokes so much untill its warmed up properly thanks for the help Link to comment Share on other sites More sharing options...
