dt 125 problems
hi ive got a dt 125 r 2002 ,
i think its lost some power beacuse first of all it was 75mph top speed on the clock, but now it struggles to go over 55mph and its never got to 75mph since
any suggestions thanks :)
Hi Leigh,
since when ? have you altered the bike some how or when did the perfomance drop off ?
Regards Jim
Hi Leigh,
Regards Jim
ive had the bike for about 2 months and within that first week of having it, it was fine then about 2 weeks after, it started to lose power, and no havnt done anything to the bike except clean it :)
but i was clocked at 65 in my dads car but my spedo said 55 so it might just be the spedos wrong but im not sure
Hi Leigh,
how many miles has the bike covered ?
Regards Jim
Hi Leigh,
Regards Jim
its done about 7700miles
Hi Leigh,
if the bike has not been serviced it may require one .... 2 stroke motors tend to build up carbon within the exhaust system which tends to restrict them, can you 'red line' the bike in the gears above third ? If not this would indicate a carbon build up. The speedo error you have is quite great and it may be worth checking this out also (assuming the old man's car's clock is correct !
Regards Jim
Hi Leigh,
Regards Jim
no i cant red line it above 3rd gear , maybe best to get it serviced because first thing in the morning it smokes so much untill its warmed up properly
thanks for the help :)
