May 9, 200916 yr Hi all I have recently acquired an XJ600N, runs fine but has what seems to be a common problem .... oil dripping from the airbox drain pipe. I've read up and thanks to many am clear on what I need to do ..... except for one thing .... When removing the fuel tank, there has been no mention of setting the tap to 'off' ( dont think there is an 'off') or draining the tank before disconnecting the pipe. Maybe im being a bit dense, but what stops the fuel running out all over the place?? Many thanks, in advance.
May 9, 200916 yr Author you will need to drain the fule befor removing the tank ok, thats cool, thought that might be the case ... just didnt wanna do stuff I dont need to. Cheers
May 9, 200916 yr You dont to have to drain fuel, turn the petcock to on, as the fuel is vacuum fed to the carb it wont run out, you will have a small amount from the pipe but thats all,
May 9, 200916 yr Author You dont to have to drain fuel, turn the petcock to on, as the fuel is vacuum fed to the carb it wont run out, you will have a small amount from the pipe but thats all, now thats even better cheers dude
