Well i get to the point. I just bought a 1995 yamaha yzf 600. First thing is the throttle doesn't snap back, how do you fix that or what will be a good place to look up for that. Second thing is I stick the key in and it has a hard time turning over the on poistion, how u fix both. Let me know please thank you very much.
Funnily enough my brother noticed that his throttle didn't snap back yesterday on his R1 and found that the actual rubber grip was rubbing on the bar end so he twisted and pushed the grip round till it didn't rub. If its not that its probably the cable wants lubing or replacing. Try squirting a bit of wd40 down the switch with the key half in this might help if not it may be the switch is worn.Tony.
Ok I'll try that later in the day, thank you for your help.
