May 7, 200916 yr Today i took off my headlight connector to put halogen bulbs in and reconnected the connectors all i did didnt touch anything else and no only have high beam and sidelights on my fzr400 3en1 model
May 7, 200916 yr difficult to diagnose without seeing the bike, but if it worked before you changed the bulbs, maybe the connector isnt on properly or maybe you got grease or fingerprints on the bulb and its overheated and blown.
May 10, 200916 yr Author difficult to diagnose without seeing the bike, but if it worked before you changed the bulbs, maybe the connector isnt on properly or maybe you got grease or fingerprints on the bulb and its overheated and blown. Presume it was just a bit of crap got on there as i went out on a 50 mile ride and by the time i got home they had come on again Thanks for the advice Just need to find out what the fitting is now to go onto halogen bulbs
