Exhaust blowing
small hole in exhaust where the silencer is supposed to slip on.Unfortunately someone has tried to remove the silencer and has just messed it up and caused a small gap and now the exhaust is blowing and will fail next MOT.I have put silencer repair bandage round it but i'm not convinced it will pass next MOT like that. Took the bike to a local car repairer who is good at welding and he said if he welds it on its on permanent.
Just wondering if anyone has any ideas as to whats the best thing to do.
hi, i would like to try help. need to see a piccy of the hole and area though really, can you upload one ?
hm the best solution would be to get a standard replacment exhaust
isthe bike under waranty if so they may pay part
if not then may be good time to stick a aftermarket can on like a leo vince,scorpion,mivv,akrapovic would also up ure performance and fule economy
Think i made a mistake in putting the silencer repair bandage on it. Will have to try and get it off and go back to the drawing board but its set like rock now.
The reason its got a bit of a hole in it is because a friend tried to remove the silencer so i could put a standard one on but it seems the vance and Hines i have on it just dosnt want to come off.It seems like its been cemented on.Maybe i should just get it welded anyway.
weld it and replace when its knackered. does it get in the way of anything like wheel removal?
