May 5, 200916 yr I need to remove the fork bottoms on my r1 1998 4xv forks. There appears to be a screw on each leg but i'm not sure if i need a special tool, any help would be appreciated. Thanks Tony
May 5, 200916 yr I need to remove the fork bottoms on my r1 1998 4xv forks. There appears to be a screw on each leg but i'm not sure if i need a special tool, any help would be appreciated. Thanks Tony hi, you need a 6 or 8mm long reach allen key , prefereably one you can use on a air gun to spin the bolts out, this will allow the tops and bottoms to be separated,
May 6, 200916 yr Author I need to remove the fork bottoms on my r1 1998 4xv forks. There appears to be a screw on each leg but i'm not sure if i need a special tool, any help would be appreciated. Thanks Tony Thanks for the reply. There appears to be a torx screw on the side of each leg, do i have to remove this as well.
May 12, 200916 yr Thanks for the reply. There appears to be a torx screw on the side of each leg, do i have to remove this as well. i dont remember seeing a torx screw ,,, u dont need to remove it, are you doing fork seals or something..
May 12, 200916 yr Author i dont remember seeing a torx screw ,,, u dont need to remove it, are you doing fork seals or something.. I need to remove the fork bottoms because they are damaged. the screw i am refering to is about 5mm and its on the inside of each fork bottom. It looks like a torx screw, i've tried all my bits and none fit.
