Posted May 4, 200915 yr To continue the XS400 obsession on this site... For purely cosmetic reasons (shameful I know) I'm thinking of changing the the wheels on my XS400 from the cast alloy ones with discs to spokes with drums. Has anybody done this? I have a complete front end and swing arm and rear wheel from a XS250. I was wondering if they are a straight swap, especially thinking about the mounting of the rear brake pedal linkages and switch. All the best Caddy
May 4, 200915 yr Moderator To continue the XS400 obsession on this site... For purely cosmetic reasons (shameful I know) I'm thinking of changing the the wheels on my XS400 from the cast alloy ones with discs to spokes with drums. Has anybody done this? I have a complete front end and swing arm and rear wheel from a XS250. I was wondering if they are a straight swap, especially thinking about the mounting of the rear brake pedal linkages and switch. All the best Caddy as far as the front is concerned no problem. the rear will need the pedal and linkage to operate the rear brake
May 4, 200915 yr To continue the XS400 obsession on this site... For purely cosmetic reasons (shameful I know) I'm thinking of changing the the wheels on my XS400 from the cast alloy ones with discs to spokes with drums. Has anybody done this? I have a complete front end and swing arm and rear wheel from a XS250. I was wondering if they are a straight swap, especially thinking about the mounting of the rear brake pedal linkages and switch. All the best Caddy I'll have to say I rather like the spoke wheel look on them myself. Now if the drum brakes just worked worth a darn. What I would like to do (eventually) on my xs400 is convert to disk on the front while keeping the spoke wheels.
May 4, 200915 yr Author I'll have to say I rather like the spoke wheel look on them myself. Now if the drum brakes just worked worth a darn. What I would like to do (eventually) on my xs400 is convert to disk on the front while keeping the spoke wheels. Yes, I think the stopping power of a disc on the front would make me feel safer as well. Like yourself my long term plan is to fit a disc to the front, but to maybe use a different caliper to the stock XS400 which is a little bulky. I think a modern Brembo type caliper fitted with some kind of adapter plate would be a possibilty...
May 5, 200915 yr Yes, I think the stopping power of a disc on the front would make me feel safer as well. Like yourself my long term plan is to fit a disc to the front, but to maybe use a different caliper to the stock XS400 which is a little bulky. I think a modern Brembo type caliper fitted with some kind of adapter plate would be a possibilty... Hi Cad, just find some UK spec XS250C wheels ... spoked, drum to the rear & twin leading shoe to the front and to be honest there would be no reason to fit a disc front brake if a correctly set up TLS brake was installed. The XS250C retained the same frame but had a different S/A so with a 250C S/A and footrest mounts (where the brake cam fitted thro) you will end up with an XS400 spoked & with some drum brakes to die for. Regards Jim
May 5, 200915 yr Author Hi Cad, just find some UK spec XS250C wheels ... spoked, drum to the rear & twin leading shoe to the front and to be honest there would be no reason to fit a disc front brake if a correctly set up TLS brake was installed. The XS250C retained the same frame but had a different S/A so with a 250C S/A and footrest mounts (where the brake cam fitted thro) you will end up with an XS400 spoked & with some drum brakes to die for. Regards Jim Hey Jim I have a rear wheel and swing arm from a XS250C, but not the pedal and linkage mechanism. I was more wondering if there were any differences in the mounting points on the frames (pedal spindle mounting point and rear brake switch) from an XS400 to 250? I have the chance to buy the rest of the parts I need from a XS400 Custom and was just worrying about compatabilty really. Thanks Caddy
May 6, 200915 yr Hey Jim I have a rear wheel and swing arm from a XS250C, but not the pedal and linkage mechanism. I was more wondering if there were any differences in the mounting points on the frames (pedal spindle mounting point and rear brake switch) from an XS400 to 250? I have the chance to buy the rest of the parts I need from a XS400 Custom and was just worrying about compatabilty really. Thanks Caddy Hi Caddy, the SE frame was a wee bit different to the std one so there is a chance the SE parts will not fit, I'm not saying it would not be impossible but may need a bit of modification in order to fit. Regards Jim
