1973 250 MX
Hi, I have a really nice 73 MX 250, I bought it from the oringinal owner, Still has the bike shop sticker on it, Anyways I was puttin around on it and lost spark, I wondering where the problem typically is, A place to start, I took the stator cover off and it looks brand new, Any help would be great
Thanks
MAS
Thanks
MAS
Hi MAS, check the kill switch isnt on, if thats ok try a new plug, if that fails to spark disconnect the black / white from the Ignition coil and with a multimeter check that it isnt down to earth there.
...Paul
Have you tried a new spark plug, you may have fouled it puttin around.
  • 1 month later...
...Paul
Hey Thanks for the help Paul I still havent figured it out, Havent worked on it since posting this either, I will try that and post what I find :bc: I forgot to mention that after putting new plug in if I kick it over normally I have no spark, If kicked hard I have spark
Ya that was the first thing I tried Thanks
Weak magneto?
my dad was telling me about how his dad used to have an old BSA with a sidecar with a weak magneto, he used to take the spark plug out and warm it up on the stove or using a blowlamp to get it going, the bloke he sold the bike to put a new mag in it and it went well after that :)
its worth considering, not sure if you can test them or not
