SR500 no go
peteypops
This post is 5625 days old and we'd rather you create a new post instead of adding to this one. You can't reply in this post.
Hi folks,
finally pulled the SR out of the shed after about 5 years of hibernating behind various other motorised bicycles. Changed the oil, new plug, new fuel, checked the valve gaps, cleaned the carb, repaired/replaced various electrical connections and, b$$$$r me, it refuses to start!
Nice big juicy spark but no go.
I get the odd backfire after 5 or 6 kicks and it seems to want to pick up but just stubbornly puts its foot down.
Oh btw, its got a Boyer Bransden ignition unit fitted.
Anyone got any clues or advice???
My right leg is REALLLLLY sore!!
thanks.
Hi folks,
thanks.
You have a fueling problem.
try fuel in the bore as well, don't know if you drained the carbs before storage, otherwise its a carb strip and clean!!
Thanks for ideas folks, I think I was probably missing the obvious.
After cleaning the pilot & main jet it'll start, albeit reluctantly, and run.
However when it's stopped it's a boooooga to start again, so I'll take the advice and strip and rebuildthe carb !
Forgot how nice it sounded.
cheers.
cheers.
if you don't it going, you can give it to me ;)
Thats how I got this one in the first place bud, haha.
:lol:
Hi folks,
thanks.
With the choke on if cold or the fast idle button pressed if hot, you pull in the valve lifter and depress the kickstart until a little white mark appears in a sight window located on the end of the camshaft. When the mark appears and the valve lifter released with the ignition on give the beast a swift kick...voilla!..... :D
